dflesburg |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None ![]() |
pedal up and lots of pedal pressure but...
engine revs and nothing happens like its not in gear. I know its in gear because I can feel the gears with the shifter. the car responds like the clutch is pressed in all the time. The pedal is stiff as hell and the cable is tight. The bearing arm moves. But when I let the clutch out with the motor off and the car in gear, the car rolls . what could that be? |
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
pedal up and lots of pedal pressure but... engine revs and nothing happens like its not in gear. I know its in gear because I can feel the gears with the shifter. the car responds like the clutch is pressed in all the time. The pedal is stiff as hell and the cable is tight. The bearing arm moves. But when I let the clutch out with the motor off and the car in gear, the car rolls . what could that be? lots of things, the marcel could have broken. thats the center hub of the clutch. the input shaft of the tranny could have broke. the pinon shaft could be a goner. |
Lo-Fi Version | Time is now: 26th June 2024 - 01:27 AM |
