dflesburg |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None ![]() |
pedal up and lots of pedal pressure but...
engine revs and nothing happens like its not in gear. I know its in gear because I can feel the gears with the shifter. the car responds like the clutch is pressed in all the time. The pedal is stiff as hell and the cable is tight. The bearing arm moves. But when I let the clutch out with the motor off and the car in gear, the car rolls . what could that be? |
dflesburg |
update:
pass side axle turns backward in reverse, forward in forward gears. so you know, this is a 914-6 conversion with 914-s stub axles... more help please... |
Millerwelds |
Pleepleus ![]() ![]() ![]() Group: Members Posts: 715 Joined: 24-June 08 From: Grass Valley, CA Member No.: 9,206 Region Association: Northern California ![]() |
I'm fairly new to all this but I just swapped out my clutch and transmission and went through those systems. It almost sounds like you have the clutch cable to tight and the release bearing is doing it's job even when you have the clutch pedal up. Assuming a six is like a four with the 901 trans in place you need about a 1/2 to 3/4 free play at the clutch pedal (grab the pedal and pull towards the driver seat). Unless it is something bigger that requires dropping the trans. Might as well losen the clutch cable first and see if that helps.
Lo-Fi Version | Time is now: 26th June 2024 - 01:18 AM |
