srb7f |
Member ![]() ![]() Group: Members Posts: 157 Joined: 17-May 04 From: Roswell, GA Member No.: 2,077 Region Association: None ![]() |
Just wanted to give a shout out to Paul S (PRS914-6) who somehow has the ability to tighten the spring inside your 914 seatbelt.
I just had mine done, and they really work much better than before. Not sure if mine were worse than ordinary, but mine started where one wouldn't pull-out without locking every 3 inches and the other not retracting at all. Only $20 per pair plus shipping, with prompt turnaround. A cheap fix if your seatbelts are annoying you. Steve 74' 2.0 |
Joe Owensby |
JoeO ![]() ![]() ![]() Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States ![]() |
If you want to just re-wind the springs on your belts, it is really pretty easy. Just remove the unit, and pull the belt entirely out of the spool. You will notice that the belt goes through a slot in the center of the shaft on the spool. Take a small dull screw driver or something similar, and push the belt back through the slot. You will notice that the belt has a loop sewn on the end of it, and that it contains a pin inside the loop. When tension is placed on the belt, it pulls the loop into the shaft, and wedges it tight. It is not necessary to remove any of the covers on the ends of the belt assembly.
I used a small clamp or small vise grip pliars to hold the shaft so that it does not spin backwards, as it is still under spring tension. Push the belt out, remove the small pin from the belt loop, and then pull the belt completely out of the shaft. Then, use something like a pair of small screw drivers to wind the shaft a few turns tighter against the spring force. To do this, insert a screw drive into the slot, then remove the clamp. Rotate the shaft with the screw driver about 180 degrees, and then insert a second screw driver into the slot from the opposite side. Do this until you get the spring a little tighter. Then clamp the shaft to keep it from unwinding while you re-install the belt. To reassemble, just insert the belt back into the slot, making sure that you insert it the same way that it came out. The notch on the slot should be on the opposite side from where you insert the belt. Then put the pin back in the belt loop, and just pull on the belt so that it pulls the loop and the pin back into the slot. Remove the clamp, and let the spring wind up the belt. If you don't like the tension, just do this again. It only takes a few minutes. The photo below shows the shaft with a clamp. Note that I had the cover off the latch mechanism side, but you do not want to remove this to tighten the spring. I had mine off to make sure the latching mechanism was in good shape. Note, taht if you remove the opposite side, the spring will jump out, and you will have a mess. JoeO Attached image(s) ![]() |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:32 PM |
