OT- Hard starting BMW, Fuel injectors? |
jnp914 |
Feb 2 2004, 10:04 AM
Member Group: Members Posts: 177 Joined: 19-August 03 From: Las Vegas, NV Member No.: 1,046 |
A friend just asked for help in diagnosing his BMW:
-starts fine when cold -starts fine immediately after turning it off -impossible to start after 15 or 20 minutes -starts fine when you wait until the engine is cold To me, sounds like something in the enrichening circuit, blah blah. Any ideas? |
rdracrdave |
Feb 5 2004, 03:38 PM
Newbie Group: Members Posts: 34 Joined: 5-May 03 From: Cincinnati,Ohio Member No.: 653 |
When I worked at BMW, we would run into this problem occasionally. Usually the check valve in the fuel pump was the problem. The check valve would stay open , (dirt usually), and allow the residual fuel pressure to bleed off.
The complaint was that '" I went into the store for a gallon of milk , and it wouldnt start when I came out". The check valve is replaceable by removing the outlet line from the pump, unscrewing the valve from the pump, replacing the valve and crush washer , and reinstalling the line. Again with new washers. You also should check for vacume leaks , or a lean running condition . this can give the same simptoms. Good luck Dave |
Lo-Fi Version | Time is now: 26th June 2024 - 01:45 PM |
