jonferns |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 29-March 07 From: New Jersey Member No.: 7,631 Region Association: North East States ![]() ![]() |
I've been spending alot of my free time doing some detailing work in the wheel wells while the car was up on jackstands awaiting a replacement fuel pump. The idea was to detail the four wheel wells. On the fronts I was left with large dark spots where there was a thick buildup of road crud; the paint isn't chipped in those areas, and the spots come out when I scrape at them with my fingernail, but the spot is just too large to remove all of it that way. I was looking to see if anyone else has dealt with something like this. Maybe some sort of rubbing compound will contain just enough abrasives to remove it without harming the paint underneath? All in all, not bad for almost 40 year old paint in a vulnerable spot.
Also, the struts are left with some spots after cleaning them, what could I use to clean them up. Pat, think that "simichrome" would be a good idea to use on them? ![]() ![]() |
jonferns |
Hey Pat, thanks alot! That rust seepage is from two chips in the paint, ill make sure to treat those two chips and touch up the paint. So Pat, are you gonna make it to the AACG this year?
Pat Garvey |
Do I or don't I...........? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States ![]() |
Hey Pat, thanks alot! That rust seepage is from two chips in the paint, ill make sure to treat those two chips and touch up the paint. So Pat, are you gonna make it to the AACG this year? Jon, I'm going to try to make it, but sans Porsche. All energies are being spent on the 73T because it needs to go before winter sets in. So, if I make it, it will be in a Mercury Milan. Pat |
Lo-Fi Version | Time is now: 20th June 2024 - 09:11 AM |
