> the sinister urge, no more DSM... (and slowly getting pictures fixed in old posts)
RJMII
post Nov 3 2008, 02:49 PM
Jim McIntosh
I'm starting to re-assemble my car.
RJMII
post Jun 22 2009, 09:03 PM
Jim McIntosh
from the inside
RJMII   the sinister urge   Nov 3 2008, 02:49 PM
Root_Werks   You'll run into 100+ things you'll need wh...   Nov 3 2008, 06:36 PM
RJMII   What it looked like when I traded my Toyota 4Runne...   Nov 3 2008, 07:31 PM
RJMII   my parts car: Working over the front suspension...   Nov 3 2008, 07:37 PM
RJMII   Rear wheel on with 1" spacer. going to go wit...   Nov 3 2008, 08:15 PM
RJMII   car in the shop now: http://inlinethumb46.webshot...   Nov 3 2008, 09:39 PM
RJMII   I just like the way it looks in there: http://inli...   Nov 3 2008, 09:49 PM
RJMII   2.5 inch mandrel bent exhaust pieces for intake pl...   Nov 3 2008, 09:53 PM
RJMII   so... right now I'm at the point of going to g...   Nov 3 2008, 09:57 PM
SGB   Um... Good start! Jeeez-pers. :) :beer2:   Nov 3 2008, 10:09 PM
echocanyons   Cool Project! I stopped in Worland several y...   Nov 3 2008, 10:17 PM
RJMII   Cool Project! I stopped in Worland several ...   Nov 3 2008, 10:25 PM
RJMII   I found a picture of the engine mount being fitted...   Nov 3 2008, 10:22 PM
RJMII   and... what I get to the machine shop with while w...   Nov 4 2008, 12:33 AM
RJMII   I was doing some engine work today. If you notic...   Feb 18 2009, 11:39 AM
RJMII   Here it is with a test fit, to see where that TB e...   Feb 18 2009, 11:42 AM
RJMII   And here it is, with the top half back on and the ...   Feb 18 2009, 11:43 AM
andys   RJMII, What V6 motor is that? Andys   Feb 18 2009, 12:14 PM
RJMII   mitsubishi 6G73. 2.5 liter V-6 SOHC 24 valves; and...   Feb 18 2009, 08:50 PM
RJMII   I got the engine back in; here are the results. =o...   Feb 18 2009, 09:01 PM
RJMII   The piece of metal across the top of the firewall;...   Feb 18 2009, 09:02 PM
Solo914   The piece of metal across the top of the firewall...   Feb 18 2009, 09:40 PM
RJMII   The piece of metal across the top of the firewal...   Feb 18 2009, 10:02 PM
rick 918-S   The piece of metal across the top of the firewall...   Feb 18 2009, 11:28 PM
RJMII   Starting to look like a water cooled conversion......   Apr 7 2009, 03:49 PM
RJMII   I had my favorite machinist cut and weld the intak...   Apr 7 2009, 03:53 PM
schreiber   Helluva build thread. Keep up the good work!   Apr 7 2009, 04:06 PM
Zardozz   That's almost as crazy plumbing as mine. I...   Apr 7 2009, 04:44 PM
RJMII   downpipe from turbo to exhaust...   Apr 20 2009, 01:44 PM
RJMII   The engine is back out of the car, also. Time to ...   Apr 21 2009, 09:25 PM
RJMII   Transmission mounts. stock ones. I was under my ca...   Apr 22 2009, 07:38 PM
RJMII   Transmission mounts... 911 sport units. Twenty min...   Apr 22 2009, 07:40 PM
RJMII   Slowly getting there. =o) The downpipe needs tweak...   Apr 22 2009, 07:42 PM
RJMII   :sawzall: Back ugly bumper off. anyone want to ...   Apr 22 2009, 07:44 PM
RJMII   :sawzall: ---> that's going to get some ho...   Apr 22 2009, 07:46 PM
RJMII   every 914 owners dream... an empty jackstand. =o) ...   Apr 22 2009, 07:48 PM
RJMII   Starting fitment of the plumbing between the turbo...   Apr 30 2009, 01:20 AM
RJMII   Slowly getting there. The Orange reducer is hiding...   Apr 30 2009, 01:21 AM
RJMII   better angle... If you look at the orange, the p...   Apr 30 2009, 01:23 AM
RJMII   I scored a set of 360cc injectors. These are stock...   Apr 30 2009, 04:04 PM
RJMII   ...and installed in the fuel rail and lower intake...   Apr 30 2009, 04:07 PM
RJMII   got the angle fixed for the pipe between the turbo...   May 1 2009, 08:23 PM
JRust   Looking good Jim! Keep up the good work   May 1 2009, 08:41 PM
nsr-jamie   Wow ! That is cool !! Now I know what ...   May 2 2009, 10:49 PM
dlo914   Not going to run an intercooler?   May 2 2009, 11:58 PM
RJMII   Daniel, the plan is to go with a water to air inte...   May 3 2009, 11:06 AM
RJMII   I got the air filter, and the silicone connector f...   May 11 2009, 09:27 PM
RJMII   Here's a hole in the oil pan for the oil retur...   May 30 2009, 10:51 PM
RJMII   Oil return line installed. (It needs reconfigured ...   May 30 2009, 10:51 PM
RJMII   Oil feed line installed. =o) all of the shiny copp...   May 30 2009, 10:51 PM
RJMII   Test fitting the intake tubes with the engine in t...   May 30 2009, 10:51 PM
RJMII   While I was drilling holes for wires, throttle cab...   May 30 2009, 10:52 PM
6freak   While I was drilling holes for wires, throttle ca...   Jun 1 2009, 08:29 AM
RJMII   The wires are all sorted, and ready to be routed a...   May 30 2009, 10:52 PM
RockinOldSchool   So did you swap in HIDs after you took the pic? Or...   May 30 2009, 11:32 PM
RJMII   I'm just running the cheap Xenon bulbs for now...   May 30 2009, 11:57 PM
RockinOldSchool   I'm just running the cheap Xenon bulbs for no...   May 31 2009, 12:02 AM
RJMII   I'd be interested in the hi/low kit... I'm...   May 31 2009, 08:40 PM
RockinOldSchool   I'd be interested in the hi/low kit... I...   Jun 1 2009, 01:05 AM
3d914   Jim, This is a radical 914. Very cool! What a...   May 31 2009, 11:28 PM
RJMII   Gerard, thank you! We are aiming for 300-350hp...   Jun 1 2009, 11:02 AM
6freak   Gerard, thank you! We are aiming for 300-350h...   Jun 1 2009, 11:20 AM
RockinOldSchool   Gerard, thank you! We are aiming for 300-350h...   Jun 1 2009, 11:35 AM
RJMII   John, I've got the turn signal switch I pul...   Jun 1 2009, 12:24 PM
RockinOldSchool   I've got the turn signal switch I pulled sti...   Jun 1 2009, 01:20 PM
RJMII   Ah, with that Evo engine you are going to end up w...   Jun 1 2009, 11:39 PM
RJMII   progress picture number one from today. spaghetti...   Jun 2 2009, 01:49 AM
RJMII   Progress pic number two today! all taped up ...   Jun 2 2009, 01:51 AM
mojorisen914   It's about damn time you got out there and did...   Jun 2 2009, 02:47 AM
RJMII   It's about damn time you got out there and di...   Jun 2 2009, 02:52 AM
RJMII   test fitting the exhaust. hmm... straight out, o...   Jun 4 2009, 03:22 PM
6freak   test fitting the exhaust. hmm... straight out, ...   Jun 4 2009, 03:44 PM
RJMII   I'm test fitting the radiator... trying to g...   Jun 4 2009, 03:39 PM
JRust   "I'm test fitting the radiator... trying ...   Jun 4 2009, 05:00 PM
RJMII   6freak/Mike... here is another angle. The exhaus...   Jun 4 2009, 06:41 PM
6freak   6freak/Mike... here is another angle. The exhau...   Jun 5 2009, 08:57 AM
RJMII   Time to go put this on...   Jun 4 2009, 06:43 PM
dkjens   A friend of mine had a Mitsubishi GT3000 (regular ...   Jun 4 2009, 07:05 PM
RJMII   A friend of mine had a Mitsubishi GT3000 (regular...   Jun 4 2009, 09:13 PM
RJMII   working on bumper fitment... This thing was a pa...   Jun 4 2009, 08:57 PM
RJMII   My brakes are installed, adjusted, and bled! N...   Jun 16 2009, 06:41 PM
RJMII   where it's sitting right now. =o) on the groun...   Jun 16 2009, 06:47 PM
RJMII   While I was working on the brakes I came across an...   Jun 16 2009, 06:51 PM
neo914-6   While I was working on the brakes I came across a...   Jun 17 2009, 02:12 AM
RJMII   One last shameless plug for PMB... lol My new cl...   Jun 16 2009, 06:52 PM
ghuff   This thread is full of total fucking win. :weld...   Jun 16 2009, 08:39 PM
RJMII   you see how I've got the rotor mounted backwar...   Jun 17 2009, 03:00 AM
RJMII   removing spot welds and peeling off that 76 bumper...   Jun 18 2009, 05:27 PM
RJMII   I had to put the bumper on to see just how bad the...   Jun 18 2009, 05:28 PM
RJMII   Yes, the hammer is holding the bumper on. Just the...   Jun 18 2009, 05:29 PM
RJMII   I got some of that bondo chiseled off... time to f...   Jun 19 2009, 10:43 PM
JRust   Dude I would seriously consider replacing that fro...   Jun 19 2009, 11:11 PM
RJMII   The one on the parts car is in a whole lot better ...   Jun 20 2009, 10:31 AM
RJMII   got a little done on the car today. Changed the cl...   Jun 20 2009, 11:17 PM
RJMII   oh, I also finished installing all of the new fuel...   Jun 20 2009, 11:18 PM
RJMII   making holes...   Jun 22 2009, 09:02 PM
RJMII   from the inside   Jun 22 2009, 09:03 PM
RJMII   bigger holes   Jun 22 2009, 09:04 PM
RJMII   from the inside   Jun 22 2009, 09:05 PM
RJMII   My wife got a picture of my dad and I getting the ...   Jun 22 2009, 09:10 PM
44 User(s) are reading this topic (44 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 1st February 2025 - 09:52 AM
