914/6 axles questions |
Project 6 |
Jun 23 2009, 09:19 AM
large member Group: Members Posts: 359 Joined: 30-December 02 From: Utah Member No.: 51 Region Association: None |
OK, so I'm ready to install the engine and found a surprise. The PO was going to install a later model trans. As such, they installed 915 style stub axles. The oem stubs are lost in space.
The existing stubs don't bolt up to the 914/4 axles and CVs I was going to use. The 2.0/6 "S" spec motor puts out about 140hp. So I wasn't worried about twisting them with high torque since I used this set up with a 3.0 in the past. My questions is....are 914/6 AXLES which I might have access to, compatible with 915 sized CVs? FYI 914/6 CVs have been NLA for 20+ years.... Since I have the sub axles, can easily find drive flanges for the trans, I was thinking this would be an easy alternative. Does the 914/6 axle have the same spline count? 28 is what I've been told. Simply using a 911 axle won't work, too long. Buying 914/6 stub axles is an expensive deal, $5-600. Mittelmotor and Otto.... Some good news, I HAVE been able to locate one stub axle...it will need a little machining as it's a bit corroded. But I'm looking for alternatives. Anyone BTDT? Or even better....an orphan 914/6 stubbie? |
Cupomeat |
Jun 24 2009, 03:58 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
(IMG:style_emoticons/default/stirthepot.gif) Just FYI, the 912 shafts were used on 69-79 beetle, as the 1966-68 beetles still had a swing axle suspension. IRS came to the beetle in 69, but I believe the T3 had it in 66. I'll check that.
Cap'n Krusty |
Jun 24 2009, 07:21 PM
(IMG:style_emoticons/default/stirthepot.gif) Just FYI, the 912 shafts were used on 69-79 beetle, as the 1966-68 beetles still had a swing axle suspension. IRS came to the beetle in 69, but I believe the T3 had it in 66. I'll check that. Just how hard is it to understand that VW axles and Porsche axles have different spline counts? From the repeated attempts here to dispute that, it must be pretty damn hard. BTW, T3s had swing axles through 1968, just like everything VW except the bus which got IRS in 1968, and the aforementioned autostick cars (and automatics). The Cap'n |
r_towle |
Jun 24 2009, 07:39 PM
Custom Member Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
(IMG:style_emoticons/default/stirthepot.gif) Just FYI, the 912 shafts were used on 69-79 beetle, as the 1966-68 beetles still had a swing axle suspension. IRS came to the beetle in 69, but I believe the T3 had it in 66. I'll check that. Just how hard is it to understand that VW axles and Porsche axles have different spline counts? From the repeated attempts here to dispute that, it must be pretty damn hard. BTW, T3s had swing axles through 1968, just like everything VW except the bus which got IRS in 1968, and the aforementioned autostick cars (and automatics). The Cap'n So what your saying is that the 1968 and later buses (the modern ones) axles will fit the 914 provided you use the autostick (or automatic) transmission? Would that require the NLA microswitch? R |
Lo-Fi Version | Time is now: 26th June 2024 - 05:51 AM |
