Pics of my rotary 914, Finally finished a bunch of stuff and took some pics |
craig3x |
Jun 25 2009, 06:16 PM
Member Group: Members Posts: 106 Joined: 18-April 09 From: Sacramento Member No.: 10,275 Region Association: None |
Here is my 1974 914 with a ported 13b rotary engine. Weber 48IDA carb, Custom exhaust, 911 front end and dash. I was having tranny problems but got that solved. Now trying to dial in the front end. Has some steering shake at high speeds. A constant work in progress. Thanks for the help I got from some of you.
Rotary'14 |
Jun 25 2009, 07:26 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
Sweet ride,, I like it. (IMG:style_emoticons/default/biggrin.gif)
I have another rotary bro on here. (IMG:style_emoticons/default/drunk.gif) for strange shimmy at speed,, make sure your wheels are balanced, or rotate your tires front to rear and see if you still have the shakes. Did you ever get the jetting and fuel pressure sorted out? -Rob |
craig3x |
Jun 25 2009, 08:43 PM
Sweet ride,, I like it. (IMG:style_emoticons/default/biggrin.gif) I have another rotary bro on here. (IMG:style_emoticons/default/drunk.gif) for strange shimmy at speed,, make sure your wheels are balanced, or rotate your tires front to rear and see if you still have the shakes. Did you ever get the jetting and fuel pressure sorted out? -Rob I did balance the tires. Can't rotate em (different sizes), and no....carb is still quirky. Great idle, and great at WOT, but sputtering at cruising speeds. Gonna go to an rx-7 forum for advice. Any other ideas for the steering shake? Is this a common problem when swithing to the 911 front end? |
Lo-Fi Version | Time is now: 6th January 2025 - 03:53 PM |
