DipShit |
Member ![]() ![]() Group: Members Posts: 199 Joined: 26-May 04 From: Cheyenne, WY Member No.: 2,107 ![]() |
1.7 D-Jet
Engine was running just great until about two weeks ago, sigh. Now only fires on # 3 and # 4. I have cleaned every connection including all grounds. And I mean cleaned them good! The elecrical appears to be just fine. I get a good noid light at both # 1 and # 2. The injectors have tested just fine as well (I'm getting about 7cc in 15 seconds). I have 40lbs of pressure the 1,2 rail. The spark plugs are getting juice and fire. I have installed new points, cleaned the triggers (which shouldn't have mattered because of the sequence) and set the dwell. I'm a tad under at 44 degrees, but again shouldn't keep # 1 and # 2 from firing. The timing has to be close as it runs really smooth for just two cylinders. If I pull the power to injector 3 or 4, I get a real good drop and she will die. If I pull 1 or 2 - no change. If I add propane to the intake, I get a good response in higher rpm. I had originally traced to the Temp II sensor and it failed, so I replaced it. A new one seemed to be the fix, but only for a moment. I have good fuel, spark and air - (IMG:style_emoticons/default/WTF.gif) I'm STYMIED (or just a REAL DIPSHIT) |
DipShit |
Here is the latest that I have done and I am STILL just running on # 3 and # 4:
Cleaned and Checked all Grounds Replaced Temp Sensor II Swapped out ECU Swapped Wiring Harnmess Cleaned points, contacts and set Dwell Adjusted the timing Adjusted the valves - now 110, 110, 100, 95 was 125 120 100 80 Swapped Dizzy Cap Swapped Plug wires to test Swapped Coil Checked Fuel Pressure - 30 psi Checked Flow/Spray of Injectors 7cc in 15 seconds, nice spray pattern Still no joy with 1&2 and only running on # 3 and # 4 (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/WTF.gif) |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
Here is the latest that I have done and I am STILL just running on # 3 and # 4: Adjusted the valves - now 110, 110, 100, 95 was 125 120 100 80 Are you confusing compression testing with valve adjustment? This line does not make sense as is. What are your intake and exhaust valves set to? Did you ever test the fuel spray pattern on your injectors? How are you doing your compression test? A valve adjustment should not cause you to loose 15 psi in a cylinder, unless you are incorrectly adjusting your valves (too tight). Zach |
Lo-Fi Version | Time is now: 25th June 2024 - 05:01 PM |
