turnaround89 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest ![]() |
Is the most common length for a wheel stud for fuchs rims 45mm? Are the rear lugs supposed to be longer at 52mm, or are they also 45mm?
Also, why are wheel studs 7 dollars a stud? Have to buy 20 studs, 140 for studs is a little crazy |
pcar916 |
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None ![]() ![]() |
Interesting. I wonder if those are legal for the track. From an engineering standpoint I don't see much of a difference.
Every opening in a piece introduces a potential stressor. These holes are round so it's as good as it can get, but there are 10 instead of 5 with the offset, maybe several landings for the nuts, and maybe more weight as well. On the street it may not matter for sure. None of this helps with your original question though. I just went through my studs and don't have any stock ones to measure, so I'll not hijack the thread any further. Cheers (IMG:style_emoticons/default/beer.gif) Good luck! |
Lo-Fi Version | Time is now: 25th June 2024 - 10:37 PM |
