minnesota loon |
Member ![]() ![]() Group: Members Posts: 111 Joined: 30-September 07 From: white bear lake mn. Member No.: 8,173 ![]() |
Well something broke Dont know what. Reset timing ran great then turned it off had a run on engine.......clack,clack, clack, bent valve? Very noisy help Time to upgrade? Rebuild?76 2.0 (IMG:style_emoticons/default/confused24.gif)
charliew |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 ![]() |
I think I would take the valve cover off and look at the 4 cylinder rocker arms before the motor is dropped. Maybe it's just a broke or loose rocker. If the intake valve isn't opening it won't have any compression probably. If it's a valve seat it should have a lot of air coming out the intake or exhaust while cranking. You could just put a air hose in the spark plug hole using the compression checker hose and listen for where the air is coming out to see whats what. If the seat is loose it should be holding the valve lower under the rocker arm and the pushrod should be loose or out from under the arm maybe?
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,471 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
I think I would take the valve cover off and look at the 4 cylinder rocker arms before the motor is dropped. Maybe it's just a broke or loose rocker. If the intake valve isn't opening it won't have any compression probably. Not really. Valves need to be closed and sealed to the head to make compression. If the valve was stuck closed, it would make compression. Zach |
Lo-Fi Version | Time is now: 20th June 2024 - 11:10 PM |
