pcar916 |
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None ![]() ![]() |
I'm adding a cooler and pump to my transmission. These two pumps are similar in specification and both companies have been around a long time.
Tilton: http://www.summitracing.com/parts/TIL-40-524/ Mocal: http://www.racerpartswholesale.com/product...ial_Cooler_Pump I know several of you run Jabsco Water Puppy pumps, but I see no advantage to it over the Mocal or Tilton. Anyone out there with experience as to whether one is more reliable than the other? |
john rogers |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 ![]() |
If you hook up the plumbing system you might be surprised and how little the actual flow is with any of the pumps. On the transmissions I setup and all the ones I have seen the outlets were on top of both the gear stack and also the R&P and essentially the oil just ran down on everything. The idea is two fold, first to get the oil cooled off and second to get as much as possible onto the gears to they will then cool off.
The highest temps I ever saw were at a race in Tecate MX when it was 96 degrees during the race and the trans got to about 275 or so. The temps were high due to the constant shifting and the tight corners making the GT limited slip work really hard. At the CA speedway when temps were 104 the temp only got to 210 due to the long run time on the NASCAR portion of the track. Less shifts mean less heat build up I imagine. |
Lo-Fi Version | Time is now: 20th June 2024 - 09:03 AM |
