Mocal vs Tilton oils cooler pumps, One better than the other? |
pcar916 |
Jul 6 2009, 08:21 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
I'm adding a cooler and pump to my transmission. These two pumps are similar in specification and both companies have been around a long time.
Tilton: http://www.summitracing.com/parts/TIL-40-524/ Mocal: http://www.racerpartswholesale.com/product...ial_Cooler_Pump I know several of you run Jabsco Water Puppy pumps, but I see no advantage to it over the Mocal or Tilton. Anyone out there with experience as to whether one is more reliable than the other? |
Downunderman |
Jul 7 2009, 05:28 PM
Senior Member Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand |
I have been using the sporto pump for a couple of years now with no apparent adverse consequences; GE80 cams and VMax springs which have an open pressure of about 285 lbs. I think the pump has an internal pressure relief bypass from memory. I have also plumbed in a cartridge type filter to get rid of all the shiny bits and clutch material from the LSD which also has a pressure relief bypass in it. I am not using big revs though, about 7,200. No photos at the moment because i'm at work.
Lo-Fi Version | Time is now: 21st September 2024 - 10:02 PM |
