eg914 |
Member ![]() ![]() Group: Members Posts: 319 Joined: 17-June 04 From: Elk Grove, CA Member No.: 2,223 Region Association: None ![]() |
Pulled the trans for an oil seal replacement, and my clutch disc is down to the rivets on the pressure plate side. I thew in an old disc to keep me going (daily driver).
My question is, can I reuse the flywheel I have, or does it need to be resurfaced or replaced? How can I tell if the flywheel is OK to use as it is? Seems like the Pelican and AA kits can include flywheels, but that adds a bit to the cost. Just trying to figure out what the hit to the budget is going to be. Thanks |
Porsche Rescue |
Saving and Enjoying Old Porsches ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None ![]() |
Can you tell me the spec? Search here is unclear. Some say 11mm (disc surface to mounting surface) and others say 7-8mm. I know the plate mount surface and disc surface must be maintained at 22.5.
Lo-Fi Version | Time is now: 20th June 2024 - 06:26 AM |
