MegaSquirt and fuel pump control..., another fuel pump thread. |
RJMII |
Jul 8 2009, 04:50 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
Do any of you MegaSquirt users know of settings in MS that control the fuel pump?
It seems as if my fuel pump doesn't come on when it should. (the wiring is correct, I KNOW it isn't wiring, the board doesn't have any boviously visible trace issues, we have checked continuity through the whole system and it is either hardware issue or software) direct question: which settings for the MS will cause fuel pump issues? |
mightyohm |
Jul 9 2009, 03:07 AM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
So the fuel pump NEVER turns on?
If so, then it's a blown driver transistor in the MS or a wiring problem (I know you've checked!). I don't think there are any settings that will cause the pump to never come on. The prime pulse settings that others have mentioned only affect how long the pump runs after you turn the key to the on position (before starting). |
Lo-Fi Version | Time is now: 15th January 2025 - 04:05 AM |
