Flywheel replace?, when do you need too? |
eg914 |
Jan 12 2009, 01:30 AM
Member Group: Members Posts: 319 Joined: 17-June 04 From: Elk Grove, CA Member No.: 2,223 Region Association: None |
Pulled the trans for an oil seal replacement, and my clutch disc is down to the rivets on the pressure plate side. I thew in an old disc to keep me going (daily driver).
My question is, can I reuse the flywheel I have, or does it need to be resurfaced or replaced? How can I tell if the flywheel is OK to use as it is? Seems like the Pelican and AA kits can include flywheels, but that adds a bit to the cost. Just trying to figure out what the hit to the budget is going to be. Thanks |
JFJ914 |
Jul 9 2009, 09:31 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
You will probably be ok as long as there is still a "step" left from the working surface toward the inner atachment.
Lo-Fi Version | Time is now: 21st September 2024 - 07:05 PM |
