karmanbuilt |
??? ![]() ![]() Group: Members Posts: 72 Joined: 7-July 08 From: Emmett, ID. Member No.: 9,262 Region Association: Pacific Northwest ![]() |
This topic has probably been asked before, but.........can MFI mechanical fuel injection throttle bodies be setup on the 14, instead of running EFI?? Saw PMOs MFI for the 911, soooo.............
ghuff |
This is certainly not what I expected down here. ![]() ![]() ![]() Group: Members Posts: 849 Joined: 21-May 09 From: Bodymore Murderland Member No.: 10,389 Region Association: MidAtlantic Region ![]() |
I am not sure you can get less restrictive period than a map sensor and a wideband o2 sensor.
Can you? 3mm internal diameter map feed and the O2 in the exhaust stream. Can you have anti-lag and launch control, aka stuttering your ignition or somehow building boost at launch to avoid turbo lag? I have all of that on a stock ECU. When my TPS value > 85% and the clutch switch engages as the pedal moves my ignition cuts and raw fuel is dumped into my turbine housing igniting it between shifts and keeping boost built.... The value it cuts the ignition is selectable between 50ms-1000ms so a 90 year old could use it. Off the line I have an adjustable window to stutter my ignition to the same effect so I can leave under boost.... Can MFI do all of that? |
Lo-Fi Version | Time is now: 25th June 2024 - 10:25 PM |
