minnesota loon |
Member ![]() ![]() Group: Members Posts: 111 Joined: 30-September 07 From: white bear lake mn. Member No.: 8,173 ![]() |
Well something broke Dont know what. Reset timing ran great then turned it off had a run on engine.......clack,clack, clack, bent valve? Very noisy help Time to upgrade? Rebuild?76 2.0 (IMG:style_emoticons/default/confused24.gif)
minnesota loon |
I pulled the valve cover off. The second rocker from rear is loose(intake)? The valve spring is not compressed,(in proper position)?The push rod is not tight against the rocker. Could it be broken or bent? Any thoughts on how to proceed.
type2man |
Member ![]() ![]() Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States ![]() |
I pulled the valve cover off. The second rocker from rear is loose(intake)? The valve spring is not compressed,(in proper position)?The push rod is not tight against the rocker. Could it be broken or bent? Any thoughts on how to proceed. Look visually at the valve spring on which the rocker is loose and see if it is sunken in more than the others next to it at tdc for that cylinder. If it is you probably dropped a seat. Maybe the valve adjuster backed out, see if the nut on the rocker is tight. |
Lo-Fi Version | Time is now: 20th June 2024 - 11:19 PM |
