Car want's to keep going, All electronics including engine will not turnoff |
914coop |
Jul 12 2009, 11:45 PM
Member Group: Members Posts: 214 Joined: 5-September 08 From: Minneapolis Member No.: 9,514 Region Association: Northstar Region |
Went for my first extended trip.....300 miles. Weather was great, car ran great. Until I went to turn it off....It did not. Radio stayed on and all other electronics.
I am thinking ignition switch, However when I let the clutch out to kill the engine, the ignition switch activated the starter and it fired up and ran great, however it still would not shutdown. Any Ideas??? Thanks |
Dave_Darling |
Jul 13 2009, 01:12 AM
914 Idiot Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Crossed wires can do that. I once put a single-filament bulb in the rear turn signal housing where a dual-filament bulb should go. When I left my left turn signal on, the "parking light" function would send power to the housing, which fed back through the socket and up into the ignition switch, so the car continued to run.
You could have something similar going on... --DD |
914coop |
Jul 13 2009, 07:39 AM
Crossed wires can do that. I once put a single-filament bulb in the rear turn signal housing where a dual-filament bulb should go. When I left my left turn signal on, the "parking light" function would send power to the housing, which fed back through the socket and up into the ignition switch, so the car continued to run. You could have something similar going on... --DD I will need to check the wiring (IMG:style_emoticons/default/sad.gif) (I Hate Wiring issues) as I have not added or removed any thing in the car. It was working fine up until about 40 miles in to the trip when I was stopping for gas. It had turned on and off at least five times that morning with no issues. Thanks for the direction. |
Lo-Fi Version | Time is now: 26th June 2024 - 10:30 AM |
