914coop |
Member ![]() ![]() Group: Members Posts: 214 Joined: 5-September 08 From: Minneapolis Member No.: 9,514 Region Association: Northstar Region ![]() |
Went for my first extended trip.....300 miles. Weather was great, car ran great. Until I went to turn it off....It did not. Radio stayed on and all other electronics.
I am thinking ignition switch, However when I let the clutch out to kill the engine, the ignition switch activated the starter and it fired up and ran great, however it still would not shutdown. Any Ideas??? Thanks |
CliffBraun |
Member ![]() ![]() Group: Members Posts: 252 Joined: 26-April 06 From: San Luis Obispo,ca Member No.: 5,933 Region Association: None ![]() |
Were all of the electronics that normally come on with the key still on after you dropped the clutch and killed the engine?
There's a big red wire(IIRC) that runs switched power to the back, I've had it pull out of the connector and cause the opposite symptoms (no power). Check to see if it has power with the key off and if it does there's your problem. I'd also worry about burning out coils with constant ignition power. |
914coop |
Were all of the electronics that normally come on with the key still on after you dropped the clutch and killed the engine? There's a big red wire(IIRC) that runs switched power to the back, I've had it pull out of the connector and cause the opposite symptoms (no power). Check to see if it has power with the key off and if it does there's your problem. I'd also worry about burning out coils with constant ignition power. Yes, all the electron9cs where on after I killed the engine. I will check the "IIRC" for Power with the key off. I am currently disconnecting the battery so not to burn out coils, killing battery etc... Thanks for your ideas. |
CliffBraun |
Were all of the electronics that normally come on with the key still on after you dropped the clutch and killed the engine? There's a big red wire(IIRC) that runs switched power to the back, I've had it pull out of the connector and cause the opposite symptoms (no power). Check to see if it has power with the key off and if it does there's your problem. I'd also worry about burning out coils with constant ignition power. Yes, all the electron9cs where on after I killed the engine. I will check the "IIRC" for Power with the key off. I am currently disconnecting the battery so not to burn out coils, killing battery etc... Thanks for your ideas. IIRC= If I recall correctly. Anywho, In a 71 at least there's a red wire from a 20 or so pin connector that is the switched power from the key. I'd start by checking if it has power. You could also check to see if it was getting power from the back of the car or the switch side by testing the different sides of the connector. |
Lo-Fi Version | Time is now: 26th June 2024 - 10:34 AM |
