nycchef |
mechanical moron ![]() ![]() ![]() Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None ![]() |
so after 2 weeks of pretending that i don't own a 914, i am goin to try to get it running again. finally got new valve adjustment screws (fed-ex lost em for a while). i need to know how much to torque down the nuts on the h.e's ( if i strip a stud i will kill myself)
Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
I don't believe any torque spec is in the Haynes manual. I thought that the exhaust studs were torqued to 14 or 14.5 ft/lbs (because they're going into aluminum and the copper nuts that hold the HEs on were 12 ft/lbs.
Someone please render a decision. |
jk76.914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States ![]() |
I don't believe any torque spec is in the Haynes manual. I thought that the exhaust studs were torqued to 14 or 14.5 ft/lbs (because they're going into aluminum and the copper nuts that hold the HEs on were 12 ft/lbs. Someone please render a decision. (IMG:style_emoticons/default/agree.gif) That's right. M8 into aluminum is only 14 ft-lbs. Remember that though the nut is steel (copper-plated only!) the torque is distributed down the length of the stud, and the other end goes into aluminum. I have the Bentley manual for VW T4, and it states 14 ft-lbs also, IIRC. Interestingly, M9 into aluminum is about 17 ft-lbs, which is about the same as M8 into steel, so if you're running 9mm/8mm step studs, both ends can handle 17 ft-lbs, and you can go a but tighter. Someone correct me if I'm wrong, but didn't the 1.8 came from the factory with the 9mm/8mm step studs. My theory is that this was part of the reason. Similarly, the rocker studs are 8mm/7mm step studs, with the big end going into the aluminum head- same reason? Who knows! |
Lo-Fi Version | Time is now: 26th June 2024 - 02:38 PM |
