malaga_red75 |
'74 2.5L N/A Subie ![]() ![]() Group: Members Posts: 454 Joined: 5-March 06 From: Menlo Park, CA Member No.: 5,674 Region Association: None ![]() |
So I am using aftermarket relays for the fuel pump and the cooling fans on my subaru conversion, using the stock ECU. I have attached a picture of the relay diagram.
![]() So, there are two circuits, an 'inner' circuit and an 'outer' circuit. The outer circuit is only completed when the inner circuit's electromagnet is active. It is currently wired like this: The 'inner circuit' receives a signal from the fuel pump pin on the ECU which goes into terminal 86 on the relay. (and here is where i think it has been wired wrong), coming out of terminal 85 the wire goes into the ECU into a 12 volt power connection. This is for the 'inner' circuit which should ignite the electromagnet. --- I THINK THIS IS WRONG. ---Shouldn't the wire coming out of terminal 85 go to a ground? thus completing the inner circuit and cause the magnet to attract the arm to complete the 'outer' circuit. I hope that wasn't too confusing, let me know. Thanks a bunch! -Peter |
malaga_red75 |
Ok, so that leads to my next question, what would cause the fuel pump output signal not to switch?
Lo-Fi Version | Time is now: 25th June 2024 - 10:51 PM |
