jeffff |
Newbie ![]() Group: Members Posts: 18 Joined: 27-May 08 From: canada Member No.: 9,107 Region Association: None ![]() |
Hello, my name is Jeff and I'm the proud owner of a 73 914, 2.0 liter. I've had the car for awhile now and it has been nothing but fun and an absolute joy to own and drive.
I've been driving the car consistantly since the snow has melted and it has given me no problems........until now. After driving the car all weekend I go to start the car yesterday, and nothing, it will not turn over. It is NOT the battery, it's new, I boosted it just to make sure. I have power everywhere....gauges, radio, lights etc. Assuming it's an electrical issue I removed the fuse box to get a better look. While trying to start it I receive a "clicking" noise from the relay (black round one), far left, drivers side. I swapped out that relay for another one, it did not help. I'm stumped. Occasionally I've had to "turn the key hard" to get it to turn over. I'm thinking that this once occasional problem has become a permanent problem, but I could be wrong. I was thinking of possibly removing the steering colomn cover to gain access to the ignition switch. It could be the problem. Is this difficult to do? Hopefully my issue is just a 914 idiosyncrassy and was hoping to get some advice or suggestions from you guys. Any input greatly appreciated. Jeff |
wobbletop |
Member ![]() ![]() Group: Members Posts: 382 Joined: 8-December 06 From: Ontario, Canada Member No.: 7,335 Region Association: Canada ![]() |
Bump (pun intended?)
The wife was getting tired of push starting the car (think Little Miss Sunshine). After some debugging: Shorting the solenoid to the starter worked. Testing of the relay worked. Decided to take out the ignition switch to check it... pain in the butt. Ignition switch is fine but took the time to clean up some wiring under the dash. Turns out to be a broken wire at the large connector in the engine bay at the drivers side firewall. (I didn't know that connector was there before this). Hopefully this helps somebody. |
Lo-Fi Version | Time is now: 26th June 2024 - 01:37 AM |
