DipShit |
Member ![]() ![]() Group: Members Posts: 199 Joined: 26-May 04 From: Cheyenne, WY Member No.: 2,107 ![]() |
1.7 D-Jet
Engine was running just great until about two weeks ago, sigh. Now only fires on # 3 and # 4. I have cleaned every connection including all grounds. And I mean cleaned them good! The elecrical appears to be just fine. I get a good noid light at both # 1 and # 2. The injectors have tested just fine as well (I'm getting about 7cc in 15 seconds). I have 40lbs of pressure the 1,2 rail. The spark plugs are getting juice and fire. I have installed new points, cleaned the triggers (which shouldn't have mattered because of the sequence) and set the dwell. I'm a tad under at 44 degrees, but again shouldn't keep # 1 and # 2 from firing. The timing has to be close as it runs really smooth for just two cylinders. If I pull the power to injector 3 or 4, I get a real good drop and she will die. If I pull 1 or 2 - no change. If I add propane to the intake, I get a good response in higher rpm. I had originally traced to the Temp II sensor and it failed, so I replaced it. A new one seemed to be the fix, but only for a moment. I have good fuel, spark and air - (IMG:style_emoticons/default/WTF.gif) I'm STYMIED (or just a REAL DIPSHIT) |
DipShit |
After everything I have done, I went back to the simple thought of "the only way that # 1 and # 2 won't fire is a ground problem" I believe stated by Dr. Evil.
That was EXACTLY what was going on. I previously just looked at the ground strap and it LOOKED good. However, when I actually pulled it off the car is was actually split and corroded under the washer. I am back up and running and after the full tune of valves, dizzy, dwell and timing plus cleaning all the connections, am burning around town like a scalded cat! Thanks to all (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 05:25 PM |
