saigon71 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region ![]() ![]() ![]() |
I started looking into welding equipment for body/hell hole/jackstand repair of my 914. A friend told me that MIG is the way to go for this. My question is what specifications do I need in a MIG welder to get the job done without a lot of grief? Also, what gage steel should be used for making patches?
Thanks |
jmill |
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest ![]() |
Actually I don't agree with that at all. Inexpensive 220V units generally let you weld thicker metal single pass than 110V units, but the lower settings are pretty much (if not idential) on 110V vs. 220V. I have a 220V and a 110v. I agree to disagree with you if you have stepped power settings. Say the 110V has 10 power settings and the 220V has 10 power settings. The 220v power settings will be spaced further apart than the 110v. You have a closer gap on the thinner stuff using the 110v. All bets are off with infinite. Then I agree to agree. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 30th June 2024 - 09:00 PM |
