JOE M |
Member ![]() ![]() Group: Members Posts: 293 Joined: 27-August 07 From: N.H Member No.: 8,042 Region Association: None ![]() |
I think I know the answer but hopefully I am wrong. I was installing new rings and found that 1 piston had a chunk missing from the wall (see pic). Is there any hope for this piston or is it dead.My guess is that it is trash but can I replace a single piston or do I have to replace all 4?
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
You do not need to replace the complete set of pistons, 1 piston knows nothing of the others. You will need a piston that matches you others though.
It will need to have the correct piston to cylinder clearance, the correct weight to match the rest and a matching dish, valve relief's, pin height and anything else that will affect the compression. You don't see a lot of single pistons for sale so it might be easier to just get a matched set. Jim |
Lo-Fi Version | Time is now: 1st July 2024 - 12:07 AM |
