911 Valve Adjusters for my Type-4 2.0L?, Good Idea or Bad Idea? |
ericread |
Jul 30 2009, 03:49 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Somewhere earlier I saw a comment that Jake had recommended using 911 Valve Adjusters in the Type-4 engine... Or maybe he had recommended against it. I can't remember.
Anybody out there have experience in this? My adjusters and adjuster nuts were pretty gnarled when I got my car a few years ago. Now with bi-monthly adjustments, I'm looking to replace them. Will the 911 adjusters fit the existing rocker arms? Do I need the same nuts? If I go ahead with this, should my properly adjusted valves run quieter? And is there any advantage to replacing the springs? As a result of some moderate leaky valve guides, my plans are to have the heads re-built this winter. Should I wait until the heads are rebuilt, or is there any reason I shouldn't go ahead with the adjusters, nuts and springs right now? Any thoughts? My thanks. Eric Read |
orange914 |
Jul 30 2009, 04:32 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
you'll need a set of 1.7 rockers and then you must shave .040 off the underside where the swivel would contact when drawn up tight.
I.M.O. was a great improvement, kinda' removes some of the "thrashing machine" v.w. sound. mike |
dlestep |
Jul 30 2009, 07:58 PM
I am smilin'... Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
you'll need a set of 1.7 rockers and then you must shave .040 off the underside where the swivel would contact when drawn up tight. I.M.O. was a great improvement, kinda' removes some of the "thrashing machine" v.w. sound. mike ...would you have a photo of the removal of 1mm of material off the rocker as an example? |
Lo-Fi Version | Time is now: 25th June 2024 - 05:56 PM |
