my mallory may have died, how do I test it? |
VaccaRabite |
Aug 1 2009, 10:36 PM
En Garde! Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Engine is in. Everything is ready.
But I don't get any spark. Coil seems to be okay. I need to know if there is anyway to test the mallory? I am not getting any power to the plugs. I have tried putting a timing light on the plug wires and putting the timing light on the wire from the coil to the mallory just to see if there is currant, which there is not... I am getting power to the coil. I am SO CLOSE!!!! I just need to get this bitch running. Zach |
Kirmizi |
Aug 1 2009, 10:48 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Zach,
I just pulled out the installation instructions and there's not much there. Have you double-checked all your wiring/connections/etc...? It states, "If the engine fails to start, rotate the distributor in small increments clockwise or counterclockwise until the engine starts. Do not exceed more than ten degrees ... in either direction." Mike |
VaccaRabite |
Aug 1 2009, 10:52 PM
Zach, I just pulled out the installation instructions and there's not much there. Have you double-checked all your wiring/connections/etc...? It states, "If the engine fails to start, rotate the distributor in small increments clockwise or counterclockwise until the engine starts. Do not exceed more than ten degrees ... in either direction." Mike Saw that. Even if my timing was off, I'd be getting a pulse through the plug wires. I'm not getting any pulse. Mike (DrEvil) and I triple checked the wires. Its is in properly. Zach |
Lo-Fi Version | Time is now: 25th June 2024 - 09:26 PM |
