VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
Engine is in. Everything is ready.
But I don't get any spark. Coil seems to be okay. I need to know if there is anyway to test the mallory? I am not getting any power to the plugs. I have tried putting a timing light on the plug wires and putting the timing light on the wire from the coil to the mallory just to see if there is currant, which there is not... I am getting power to the coil. I am SO CLOSE!!!! I just need to get this bitch running. Zach |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
From Yeahmaq's link, "you will need a ballast resistor installed in the system to prevent killing a good module (if you attempt to start the engine). "
A yup, ya done kilt it with that misplaced wire (IMG:style_emoticons/default/wink.gif) |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
I didn't use a ballast resistor, but used a Bosch Blue coil. Seems like this combo works. I'm notclear when a ballast resistor is required??
From Yeahmaq's link, "you will need a ballast resistor installed in the system to prevent killing a good module (if you attempt to start the engine). " A yup, ya done kilt it with that misplaced wire (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 09:10 PM |
