VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
Engine is in. Everything is ready.
But I don't get any spark. Coil seems to be okay. I need to know if there is anyway to test the mallory? I am not getting any power to the plugs. I have tried putting a timing light on the plug wires and putting the timing light on the wire from the coil to the mallory just to see if there is currant, which there is not... I am getting power to the coil. I am SO CLOSE!!!! I just need to get this bitch running. Zach |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
And internal ballast creates resistance.
Its also called a resistor. This resistance needs to be in the system in order for your electronic sensor to function. You have two choices. 1 is buy the correct resistor and put it inline like the manual says...or you could just hand it to Dr Evil and have him wire it up. 2, you could buy a different coil that has the built in resistance you need....but the risk of that is you WILL forget when the coil gets replaced down the road... Rich |
Lo-Fi Version | Time is now: 25th June 2024 - 09:36 PM |
