ericread |
The Viper Blue 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California ![]() |
Somewhere earlier I saw a comment that Jake had recommended using 911 Valve Adjusters in the Type-4 engine... Or maybe he had recommended against it. I can't remember.
Anybody out there have experience in this? My adjusters and adjuster nuts were pretty gnarled when I got my car a few years ago. Now with bi-monthly adjustments, I'm looking to replace them. Will the 911 adjusters fit the existing rocker arms? Do I need the same nuts? If I go ahead with this, should my properly adjusted valves run quieter? And is there any advantage to replacing the springs? As a result of some moderate leaky valve guides, my plans are to have the heads re-built this winter. Should I wait until the heads are rebuilt, or is there any reason I shouldn't go ahead with the adjusters, nuts and springs right now? Any thoughts? My thanks. Eric Read |
type11969 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States ![]() |
It does not need to be precise, you can do it with an angle or die grinder. You should try to minimize the number of sharp edges/stress risers, especially ones that cut across the rocker. Better to grind along the length of the rocker which, of course, is more difficult.
ericread |
It does not need to be precise, you can do it with an angle or die grinder. You should try to minimize the number of sharp edges/stress risers, especially ones that cut across the rocker. Better to grind along the length of the rocker which, of course, is more difficult. You've got to understand, power tools and I do not get along very well. Usually ending up in crying, massive amounts of blood and a garage that looks like it hosted a slasher movie. ![]() |
Lo-Fi Version | Time is now: 29th June 2024 - 03:32 AM |
