ericread |
The Viper Blue 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California ![]() |
Somewhere earlier I saw a comment that Jake had recommended using 911 Valve Adjusters in the Type-4 engine... Or maybe he had recommended against it. I can't remember.
Anybody out there have experience in this? My adjusters and adjuster nuts were pretty gnarled when I got my car a few years ago. Now with bi-monthly adjustments, I'm looking to replace them. Will the 911 adjusters fit the existing rocker arms? Do I need the same nuts? If I go ahead with this, should my properly adjusted valves run quieter? And is there any advantage to replacing the springs? As a result of some moderate leaky valve guides, my plans are to have the heads re-built this winter. Should I wait until the heads are rebuilt, or is there any reason I shouldn't go ahead with the adjusters, nuts and springs right now? Any thoughts? My thanks. Eric Read |
type11969 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States ![]() |
When you say "work properly", what do you mean? Are you talking about the swivel foot contacting the rocker even with .060" removed at some point during the rockers' sweep? I agree that this needs to be checked but is this really checking the geometry? If there is binding, then yes, you would have to shim the rockers out or adjust the pushrod length which would entail re-setting the geometry.
But if there is no binding, and the geometry was fine from the start, then you are still fine because from a geometrical standpoint, nothing has changed. |
Lo-Fi Version | Time is now: 30th June 2024 - 06:12 PM |
