ME733 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States ![]() |
Well for what it,s worth I would like to make a comment addressed to everyone about ......FIRES and destroyed cars...After doing some reading on 914 world, and other places it seems to be an unfortunate occurance, too often, that an otherwise beautiful car, just burns to the ground,into a virtural pile of unsalvagable parts.a crispy critter. I would like to recommend that the FIRST PROJECT YOU DO NEXT...is to throughly check every part on your fuel and fuel delivery system to ensure that there are zero leaks,and tight fittings,with new, er,ish, good fuel lines.Do not neglict the gas tank,or fuel pump, and filters..suspect everything, assume nothing... jump in and make your suggestions,and recommendations or comment.
Katmanken |
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest ![]() |
After having watched one burn from an on the top of the engine gas leak, I can say that if the fuel lines on the top of the engine take a dump, the flaming gas will pour under the car and burn through the plastic lines unde the car. If that happens, there is a lot less chance of stopping it as the gravity fed gas pours from the new lower exit under the engine compartment...
Lo-Fi Version | Time is now: 26th June 2024 - 02:41 AM |
