kenshapiro2002 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region ![]() |
When I turn my key all the way, right before it engages the starter, it (fuel pump? Solenoid?) goes "click...click...click" about ten times, with diminishing frequency and stops. Again, this is before engaging the starter.
jmill |
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest ![]() |
(IMG:style_emoticons/default/popcorn[1].gif) There CAN BE a significant advantage to the CLICKING PUMP...If you pay attention....Sense, or time the clicks before it stops....IF IT KEEPS CLICKING you have a FUEL LEAK.,or a stuck and open float needle valve(now flooding your engine), or possably you are out of fuel (your guage broke),or ...can we think of some more advantages?...You do not hear it when the engine is running,so whats a little noise..use it as a tool. (IMG:style_emoticons/default/popcorn[1].gif) That's a new one. I don't know too many folks that defend the clicky pump. If you keep your fuel system maintained you don't have to worry about leaks or stuck floats. How can having 1 psi at 15 gph be better than 30 gph at a constant 3.5 psi? At high rpm, when you need the most fuel, your clicky pump can't hang. Fuel pressure with that thing goes up and down like a yo-yo. The major disadvantages outweight your perception of any advantage. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:30 AM |
