kenshapiro2002 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region ![]() |
When I turn my key all the way, right before it engages the starter, it (fuel pump? Solenoid?) goes "click...click...click" about ten times, with diminishing frequency and stops. Again, this is before engaging the starter.
jmill |
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest ![]() |
What access hole? Is there one in the pan below the tank? Yup. Passenger side. Round cover. If you pull that cover off you can get to the bottom of the tank. It's big enough to get one hand in and reach the tank fittings. Look here. Nice thread on the topic. http://www.914world.com/bbs2/index.php?sho...mp;hl=fuel+pump |
orange914 |
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California ![]() |
What access hole? Is there one in the pan below the tank? Yup. Passenger side. Round cover. If you pull that cover off you can get to the bottom of the tank. It's big enough to get one hand in and reach the tank fittings. Look here. Nice thread on the topic. http://www.914world.com/bbs2/index.php?sho...mp;hl=fuel+pump aren't front fuel pump access holes only on 74 and up? |
kenshapiro2002 |
I know my '70 doesn't have one. Besides (going against the wisdom amassed here), seems to be more access room right where it is than under the tank (regardless of access holes big enough for one hand), and unless heat (vapor lock) is an issue, how much can six feet difference make to a pump picking up gas from a gravity fed hose ?
orange914 |
I know my '70 doesn't have one. Besides (going against the wisdom amassed here), seems to be more access room right where it is than under the tank (regardless of access holes big enough for one hand), and unless heat (vapor lock) is an issue, how much can six feet difference make to a pump picking up gas from a gravity fed hose ? yes, vapor lock is one of the issues. many benifits to front mounted pumps |
Lo-Fi Version | Time is now: 25th June 2024 - 07:40 PM |
