> Let's save another 914, and get it decent., Probably need advice from you old school 914 folk
ghuff
post Jun 24 2009, 05:53 PM
This is certainly not what I expected down here.
So here is the rust on this one. It's a 75 cali car it's entire life.
Get the worst over to begin. Let us take a look at the hell hole. It was solid, and even passed teh screwdriver/hammer test....
*until* it soaked in metal ready a while... then the screwdriver test started picking out giant holes which you see here. It is still soaking, and has been on/off for days not to eat away more to see what metal is truly left. Next step is a grinder or non-hand tool of sorts to break deep into the pitting and see what truly is through.
(IMG:http://www.914world.com/bbs2/uploads_offsite/img196.imageshack.us-179-1269644411.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/img197.imageshack.us-179-1269644412.2.jpg)
ghuff
post Aug 14 2009, 10:19 PM
Thanks for the encouragement. The floorpan is getting even cleaner. I have moved from metal ready to navel jelly.
The navel jelly really seems to be destroying the rust in the pits, and a wire brush brings the new solid gook compound out of the pits leaving them pretty damn clean.
I bought a 4.5" disc sander/grinder and some 24-60 grit wheels for it to knock more metal away and get access to the deeper pitting. i just want to be sure in 5 years or so the por-15 is still happy.
I am going to try using the cold galvanizing compound on all the bare metal I end up with. fourblades reported good results and at 5.50$ a can being 93% zinc + laying like primer I am confident if any moisture settles due to humidity it will be blocked.
I think the metal ready was not thick enough and since you rinse it with water, the moisture settling actually "washed it away" in small spots causing flash to start, then creep around.
I am going to try and get the floors 100% stripped and then in cold galvanizing compound before I move on to drilling spotwelds.
Any tips for removing the center tunnel and the crossbrace? Are the front seat height/bracket things welded to the floor as well, or only to the brace?
ghuff   Let's save another 914, and get it decent.   Jun 24 2009, 05:53 PM
SLITS   That's nothing .... never penetrated the long....   Jun 24 2009, 05:57 PM
veltror   I wish mine was as good as this...   Jun 24 2009, 06:11 PM
SLITS   I wish mine was as good as this... No shit Dick...   Jun 24 2009, 06:14 PM
Vacca Rabite   I wish mine was as good as this... No shit Dic...   Jun 24 2009, 06:18 PM
r_towle   That is really in great shape compared to what we ...   Jun 24 2009, 06:22 PM
ghuff   Next up, the side opposite of the hell hole. This ...   Jun 24 2009, 06:23 PM
McMark   What you've got doesn't need saving it jus...   Jun 24 2009, 06:29 PM
ghuff   Here is the drivers side hack box, and the center ...   Jun 24 2009, 06:34 PM
ghuff   Passenger side jack box and long. The rear portio...   Jun 24 2009, 06:38 PM
Heeltoe914   You have no problems easy fix. All parts you can...   Jun 24 2009, 06:47 PM
shoguneagle   Your 914 is completely restorable and should be. ...   Jun 24 2009, 07:03 PM
tat2dphreak   I cut my bad jackpost off, and welded a piece wher...   Jun 24 2009, 07:15 PM
ghuff   The front trunk looks like it was curbed at some p...   Jun 24 2009, 08:47 PM
RobW   I dig that color. Its time for an ez resto.. got c...   Jun 24 2009, 09:00 PM
ghuff   I dig that color. Its time for an ez resto.. got ...   Jun 24 2009, 09:12 PM
ghuff   Here is what the exterior looks like. It was gett...   Jun 24 2009, 09:09 PM
ghuff   http://www.914world.com/bbs2/uploads_offsite/img15...   Jun 24 2009, 09:18 PM
ghuff   Forgot to add these, this is what I had to sculpt ...   Jun 24 2009, 09:30 PM
ghuff   About the sill to long brace on the drivers side, ...   Jun 25 2009, 09:06 AM
McMark   The pipe will be fine 99% of the time. You won...   Jun 25 2009, 04:17 PM
ghuff   The pipe will be fine 99% of the time. You won...   Jun 30 2009, 11:01 PM
ghuff   The hell hole, or lack thereof. The hole in the f...   Jun 30 2009, 11:06 PM
ghuff   Floors, wheels, frame rails. Then door handles. Th...   Aug 13 2009, 07:35 PM
ghuff   Looked worse than it was. I will be grinding the d...   Aug 13 2009, 11:35 PM
ghuff   How far down does the engman kit come on the longs...   Aug 13 2009, 11:41 PM
ghuff   Cleaner metal http://www.914world.com/bbs2/upload...   Aug 14 2009, 10:47 AM
type47   Nice work. This car will be one you'll be prou...   Aug 14 2009, 10:55 AM
ghuff   Nice work. This car will be one you'll be pro...   Aug 14 2009, 11:06 AM
Vacca Rabite   Couple small patches in the hell hole - NBD. Great...   Aug 14 2009, 11:12 AM
ghuff   Thanks for the encouragement. The floorpan is gett...   Aug 14 2009, 10:19 PM
ghuff   Pedal cluster rebuild is complete with bronze bush...   Sep 19 2009, 08:44 PM
FourBlades   You might want to paint over the clean metal with ...   Sep 19 2009, 09:23 PM
ghuff   You might want to paint over the clean metal with...   Sep 22 2009, 12:15 AM
ghuff   This car has a new head/head(s) on at least the dr...   Sep 22 2009, 01:33 PM
ghuff   Ok I am motivated again, and now I also have a new...   Feb 7 2010, 10:15 PM
ghuff   Welded up two of these lame u shaped stamps in the...   Feb 7 2010, 10:32 PM
ghuff   Spotweld cutter kit arrived today. I sprang 97...   Feb 9 2010, 08:21 PM
ghuff   These cutters kick ass. The 1/4" is a little ...   Feb 10 2010, 01:08 PM
ghuff   Lots of progress. I am laying out plants for a rot...   Mar 19 2010, 10:10 PM
ghuff   http://www.914world.com/bbs2/uploads_offsite/img14...   Mar 19 2010, 10:16 PM
ghuff   http://www.914world.com/bbs2/uploads_offsite/img19...   Mar 19 2010, 11:10 PM
ghuff   http://www.914world.com/bbs2/uploads_offsite/img87...   Mar 19 2010, 11:16 PM
Andyrew   Thats ugly. Start sourcing a replacement rear fe...   Mar 20 2010, 12:36 AM
ghuff   They botched the door handle shave so bad they had...   Mar 20 2010, 09:08 AM
1968Cayman   Eh, just buy some body hammers and a shrinking dol...   Mar 20 2010, 05:45 PM
ghuff   Eh, just buy some body hammers and a shrinking do...   Mar 20 2010, 07:18 PM
ghuff   The passenger rear 1/4 and fender are fucked. I am...   Mar 21 2010, 05:49 PM
FourBlades   That will be a nice solid car when you are done wi...   Mar 21 2010, 05:52 PM
ghuff   That will be a nice solid car when you are done w...   Mar 21 2010, 06:02 PM
scotty b   It's all fixable. Get the paint and bondo off ...   Mar 21 2010, 05:52 PM
ghuff   B)-->
QUOTE(scotty b @ M...   Mar 21 2010, 05:58 PM
scotty b   80 is plenty fine. I strip with 36 grit then use 8...   Mar 21 2010, 06:25 PM
ghuff   B)-->
- Lo-Fi Version Time is now: 3rd April 2025 - 08:00 PM
