velum |
Member ![]() ![]() Group: Members Posts: 50 Joined: 4-June 08 From: Montréal, Qc, Canada Member No.: 9,135 Region Association: None ![]() |
Hi everybody,
The fuel pump in my '73 914 2.0L FI is leaking and I need to replace it. I was a bit upset to discover that this part is discontinued, and then I found "rebuilds" at AutomobileAtlanta. Well, after installing three of their so called "rebuilds" that were not working, they admitted that they are selling imitations made in China (http://www.autoatlanta.org/detail.lasso?Pa...ial_number=7902). (IMG:style_emoticons/default/headbang.gif) They will refund me, but what a watse of time. Now, I am not sure of what I can do. I searched the web, and all I can find are all kinds of fuel pumps for the 914 (like inline fuel pumps) that have only two hose connections on them. Mine has three. I also read discussion threads from people using non-oem fuel pumps in their 914s and some of them had problems after a while. In other words, I would feel much better, if I could find an OEM fuel pump. Do you know if someone still sells them? Another alternative would be to fix my fuel pump, but I don't know if that is possible at all. Cheers! JF |
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
Any fuel pump that meets the pressure rating/flow/gpm for your carb or fuel injection system will work. If you need more delivery points, down stream splitters work.
Just make sure the hoses, filters and fittings exceed the pressure rating for the pump. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:37 AM |
