velum |
Member ![]() ![]() Group: Members Posts: 50 Joined: 4-June 08 From: Montréal, Qc, Canada Member No.: 9,135 Region Association: None ![]() |
Hi everybody,
The fuel pump in my '73 914 2.0L FI is leaking and I need to replace it. I was a bit upset to discover that this part is discontinued, and then I found "rebuilds" at AutomobileAtlanta. Well, after installing three of their so called "rebuilds" that were not working, they admitted that they are selling imitations made in China (http://www.autoatlanta.org/detail.lasso?Pa...ial_number=7902). (IMG:style_emoticons/default/headbang.gif) They will refund me, but what a watse of time. Now, I am not sure of what I can do. I searched the web, and all I can find are all kinds of fuel pumps for the 914 (like inline fuel pumps) that have only two hose connections on them. Mine has three. I also read discussion threads from people using non-oem fuel pumps in their 914s and some of them had problems after a while. In other words, I would feel much better, if I could find an OEM fuel pump. Do you know if someone still sells them? Another alternative would be to fix my fuel pump, but I don't know if that is possible at all. Cheers! JF |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Just buy the single in / single out used on the '75-'76. The third tit on the stock pump is useless and probably causes more problems than it can cure.
You just remove the "T" in the return line. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:23 AM |
