T H O M A S |
Senior Member ![]() ![]() ![]() Group: Members Posts: 626 Joined: 1-August 03 From: Donaueschingen, Germany Member No.: 974 Region Association: None ![]() |
inspired by a recent threat here about lightning gears and there benefits ,i decided to give it a shoot and wire edm 1st and 2nd gear .the weight difference form stock to modified is
3rd gear .3764kg ( the lightest gear to slow down for shifting) 2nd gear was .5078kg is now .4398kg 1st gear was .6754kg is now .5468kg gears have bin cryo treated after the machining for testing the transmission will be mated to a 200hp /4 engine i let everybody know if the gears survive and if it makes a difference in shifting Attached image(s) ![]() |
T H O M A S |
the foaming might be a problem ,one side of the holes is covered by the dog teeth and the other side is close to the intermittent plate, will see ,the first gear set is going in a daily driver with a big /4
Lo-Fi Version | Time is now: 22nd June 2024 - 08:46 PM |
