Lighting Woooes - Electrical Genius Needed, What's the next step? ?? |
bandjoey |
Aug 20 2009, 11:16 PM
bandjoey Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
???????? (IMG:style_emoticons/default/headbang.gif)
Rear Light Bulbs Numbered Outside to Inside, 4 Being the Backup Light 1234 4321 Front Marker is A Front Turn/Flasher is B ______Flashers On_______________ Front Left A & B only Nothing on Right side front Rear Left 2 Right 2 _________________________ ________________________ Ignition Switch OFF or ON with head light switch pulled full out: Front Left A & B only. Nothing on Right Side Front Rear Left 1 & 3, Right Side Nothing _________________________ _______________________ Brake Pedal Depressed Switch OFF Nothing: Brake Pedal Depressed Switch ON: Left 3 & Right 3 _________________________ ________________ No Turn Signals on Any Corner _________________________ ________________ Bulbs Replaced and contacts - grounds sanded cleaned at each bulb Pulled Hazard Switch in and out a dozed times per Haynes New Fuse Set per Specs Interior light and Trunk light work just right License Plate Lights work just right Hi/Lo beams work just right What else do you need to know? Thanks Bill |
roadster fan |
Aug 21 2009, 09:45 PM
Project Frankenstein !!!!!!!! Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
What year car? I will look at the schematics and see if I see anything obvious.
Check all the grounds at the body connection points. It looks like you need to trace the right side wiring as not much works over there. I will look at the schematics the lighting is probably almost the same for all years. Jim |
Lo-Fi Version | Time is now: 25th June 2024 - 01:16 AM |
