bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
???????? (IMG:style_emoticons/default/headbang.gif)
Rear Light Bulbs Numbered Outside to Inside, 4 Being the Backup Light 1234 4321 Front Marker is A Front Turn/Flasher is B ______Flashers On_______________ Front Left A & B only Nothing on Right side front Rear Left 2 Right 2 _________________________ ________________________ Ignition Switch OFF or ON with head light switch pulled full out: Front Left A & B only. Nothing on Right Side Front Rear Left 1 & 3, Right Side Nothing _________________________ _______________________ Brake Pedal Depressed Switch OFF Nothing: Brake Pedal Depressed Switch ON: Left 3 & Right 3 _________________________ ________________ No Turn Signals on Any Corner _________________________ ________________ Bulbs Replaced and contacts - grounds sanded cleaned at each bulb Pulled Hazard Switch in and out a dozed times per Haynes New Fuse Set per Specs Interior light and Trunk light work just right License Plate Lights work just right Hi/Lo beams work just right What else do you need to know? Thanks Bill |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
If I remember correctly, both front and rear harnesses feed from the driver's side to the passenger side, so you can trace the wires as well to look for any breaks.
I would agree that checking the grounds would be the first step. |
Lo-Fi Version | Time is now: 25th June 2024 - 12:39 AM |
