Front Wheel Bearings:, How tight is too tight? |
SirAndy |
Aug 23 2009, 09:34 PM
Resident German Group: Admin Posts: 41,945 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
My frontend has felt a bit shaky lately so i decided to check on the wheel bearings.
The drivers side felt tight but the passenger side had a bit of play and "The Clunkâ˘" when i wiggled the wheel with my hands. After removing the wheel and the dust cap, i first checked if i could rotate the clamp with a large flat screwdriver. Nope, good. Then i went to check the washer behind the clamp as you're supposed to just barely move it with a screwdriver. Nope, rock solid. Hmmmm. So i loosen the clamp nut and sure enough, i can move the clamp a good 1/3 rotation tighter with my screwdriver. I check the washer again, rock solid. Hmmmm. I tighten it all up, put the wheel back on and no more clunk or play. The wheel still rotates freely. Yet, i was under the impression that you should always be able to move that washer behind the clamp. But if i loosen the clamp enough to just barely be able to move the washer, my wheel feels lose and wiggles and clunks. So how tight is too tight for those bearings? (IMG:style_emoticons/default/idea.gif) Andy |
PanelBilly |
Aug 23 2009, 09:57 PM
914 Guru Group: Members Posts: 5,864 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Andy/ It's been so many years since I've driven my car, but I remember playing with the tightness of the nut for hours. I tried to figure out what was just the perfect balance between the slop and proper snugness. Wheel on, feel for slop, wheel off, slight adjustment, wheel on, Over and over till I was happy. Then I took it for a drive and felt it for heat build up. I may have not been a scientific method, but I could feel the difference in the front end
Lo-Fi Version | Time is now: 27th December 2024 - 09:27 AM |
