greenie |
Senior Member ![]() ![]() ![]() Group: Members Posts: 873 Joined: 26-October 04 From: Trinidad Member No.: 3,013 Region Association: Pacific Northwest ![]() |
A couple of weeks back during our very hot weather my car just dies while I'm driving. After figuring out that the fuel pump relay was not clicking and I had no power to the pump I chased everything I could using Brad Anders article. I had an extra relay board so I swapped it just for fun , hooked everything back -up and nothing. I tried again a few minutes later and everything worked! So today I start the car for the first time in weeks. Immediately when I switch on the key I hear the relay click, everything sounds fine except the pump runs continuously ( not the 1.5 seconds that it should). I crank the starter it fires up, I turn the key to off , the engine is still running. I can pull the key completely out and the engine still runs. I think I need the tumblers & electrical portion but don't know where to buy? |
zonedoubt |
Canadian Member ![]() ![]() ![]() Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada ![]() |
http://www2.cip1.com/ProductDetails.asp?Pr...171%2D905%2D865
http://www2.cip1.com/ProductDetails.asp?Pr...191%2D905%2D855 (if you don't mind an ignition key different than doors) I just replaced my lock cylinder with new as above. The little tab at the end had worn down so wasn't making good contact with the electrical part of the switch. Who knows how long a used 914 lock cylinder will last? These parts DO wear out after time. |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:29 PM |
