Dwell increasing with RPMs |
Ferg |
Aug 24 2009, 11:37 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Dwell is 49 at idle, jumps to 50 just off idle and goes all the way to 53 at full advance (3500 rpms), advance and retard hoses were hooked up for dwell check, I know to unhook them for timing. Is that right, or do I need to unhook them for dwell, as well.
Possible dizzy advacing plate issue? Car has a miss at 3kish, I'm trying to squash. Stock 74 2.0 djet. timing is set at 29. |
SLITS |
Aug 25 2009, 08:40 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
The points are a spring. If you activate the spring in enough cycles per minute you can get spring bounce just like a valve spring (kinda like floating the valves) in which the dwell would change with RPM.
Try a new set of points for fun or just get an electronic module (I prefer Led trigger, but your experience may be different) that would not be subject to dwell changes. Ferg, you are WAY to anal. That's 3 cups of coffee thoughts. |
ME733 |
Aug 25 2009, 08:56 AM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
The points are a spring. If you activate the spring in enough cycles per minute you can get spring bounce just like a valve spring (kinda like floating the valves) in which the dwell would change with RPM. Try a new set of points for fun or just get an electronic module (I prefer Led trigger, but your experience may be different) that would not be subject to dwell changes. Ferg, you are WAY to anal. That's 3 cups of coffee thoughts. (IMG:style_emoticons/default/agree.gif) And as suggested ,the shaft in the distributor....may have some wobble, due to it,s age and it,s old and all the perfect is gone!!....bouncing points , at 3000 rpm,s...guess what they are doing at even higher rpm,s.!!...this is probably the cause of the misfires when driving....replace the points,and condenser, with a new bosch set.....if the problems persist/ dwell changes/...it,s probably time for a NEW distributor...and trigger it with led...put these problems behind you as it ain't likely to heal itself....good luck. |
Lo-Fi Version | Time is now: 27th December 2024 - 10:54 AM |
