rocker question |
rocker question |
JOE M |
Aug 26 2009, 05:24 PM
Member Group: Members Posts: 293 Joined: 27-August 07 From: N.H Member No.: 8,042 Region Association: None |
Just a quick question and hopefully someone has a pic. I have a 1.7L and recently replaced my piston rings. To make a long story short I did not document the location of each rocker when I removed them. I notice that I can actually install the rockers in several different places. I just want to make sure that I put them back in correctly. I know they have different angles but like I said it is possible to install them in different places. They all have stamps on them with numbers /letters so I am guessing that this means where they should go. Any help would be appreciated.
Thanks Joe |
Jake Raby |
Aug 27 2009, 10:24 AM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
The angles are differernt on the intake and exhaust rockers.
Place them on a rocker shaft and you'll see that the angles vary vastly. The rockers with the steepest angles are the exhaust rockers, they go OUTBOARD on the cylinder heads when being installed. The intake rockers will be the remaining rockers and they have less angle and go INBOARD on each cylinder. You wouldn't have needed to ask this question if you had my DVD, I illustrate the differences clearly. :-) |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:46 PM |
