Wardsweb |
Member ![]() ![]() Group: Members Posts: 60 Joined: 8-September 08 From: San Antonio, TX Member No.: 9,527 Region Association: None ![]() |
Should I use a thin wheel spacer or grind down the BMW calipers so they don't rub the Fuchs? Everything is already mounted with a washer on each lug so they don't rub, but I want a more permanent solution. I don't need much but wanted some insight before I just grind on the caliper.
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
You may find that grinding the caliper turns it into a leaker. I've seen it before, and VERY little was removed from the offending surface. Just one of the reasons I don't install BMW calipers, besides the liability factor. Buy spacers. The Cap'n
Lo-Fi Version | Time is now: 27th June 2024 - 08:31 PM |
