kenshapiro2002 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region ![]() |
My "new" 1970 914 has a working speedo, but the odometer isn't working. The seller said it's most likely an internal gear that he's seen folks replace rather easily. Any experience out there on this one? Also, the trip odometer isn't working and the reset button seems not to exist. It's not under the dash.
??? Ken |
ejm |
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,695 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None ![]() |
The gear usually does not need replacement. The fix is to disassemble the head and knurl the shaft where the gear is so the shaft turns with the gear as it did when new. The trip counter should work once the odometer is fixed. The reset is a knob not a button. Should be under the dash to the right of the steering column and the knob will only turn one way.
lotus_65 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region ![]() |
The gear usually does not need replacement. The fix is to disassemble the head and knurl the shaft where the gear is so the shaft turns with the gear as it did when new. The trip counter should work once the odometer is fixed. The reset is a knob not a button. Should be under the dash to the right of the steering column and the knob will only turn one way. i'm doing this (knurling the shaft) tonight, as opposed to the method on the pelican site. how did this happen? QUOTE NEVER reset the trip odometer while you are moving. (IMG:style_emoticons/default/stromberg.gif) shit |
Lo-Fi Version | Time is now: 26th June 2024 - 04:24 AM |
