> The Schreiber Build Thread
schreiber
post Aug 29 2008, 01:13 PM
Greetings all! I guess this will serve as a central introduction/ build/ update thread for my teener. A little about me: I've been a member of the site for a year or so. I'm a full time student, work full time as a networks administrator, and am a member of the Marine Corps reserve.
I hope to take this car back to a factory original look... Not down to the last bolt, but given the choice, I'll probably choose the factory look. I've really enjoyed reading the enthusiasm of Pat Garvey and crew in the 'Originality & History' section.
Finally, the 914 is and will be a learning experience for me. I'll admit I have a lot to learn, but I've enjoyed playing around with it so far.
..Also want to give a shoutout to my neighbor, Scott (SGB). He has a beautiful 914, and has been an inspiration with regards to the car. I can only hope I get mine looking like his some day.
Mine:
More pictures to follow!
schreiber
post Aug 28 2009, 08:52 AM
think everything is in place. only problem now is the gas pedal not wanting to return. i'll fiddle with things more this weekend; i don't think my throttle cable is quite right.
(IMG:style_emoticons/default/smash.gif)
Mark Henry
post Sep 1 2009, 05:23 PM
that's what I do!
QUOTE(schreiber @ Aug 28 2009, 10:52 AM) *
Your linkage is all f'ed up, the arms should be 90 degrees from the throttle shaft.
In this pic you're getting closer than the first pic but still not quite right. Flip your arms in the center see if that helps. The cable must be straight and true, any kinks and it won't work right. You will need a light spring on the center pull.
Man that center looks bent.....and how it bolts to the case is cheesy.....
rick 918-S
post Sep 2 2009, 07:30 AM
Hey nice rack! -Celette
QUOTE(Mark Henry @ Sep 1 2009, 03:23 PM) *
(IMG:style_emoticons/default/agree.gif) That center pivot mount is a pending disaster. You need to make one that mounts on two bolts or it will just tip over. The flat bar cable mount will flex and the hiem joint linkage is crossed up. Also the bolt sticking up on the end of that cable is going to hook onto the heim linkage as it passes over the cable end and hold the throttle open.
schreiber   The Schreiber Build Thread   Aug 29 2008, 01:13 PM
schreiber   So far most of the stuff I've attempted has be...   Aug 29 2008, 01:15 PM
rmital   Big glaring things to work on in the future: -New...   Aug 29 2008, 02:14 PM
SirAndy   I hope to take this car back to a factory origina...   Aug 29 2008, 02:23 PM
ruddyboys   I have never seen seat belts like those before   Aug 29 2008, 04:32 PM
SirAndy   I have never seen seat belts like those before :...   Aug 29 2008, 05:18 PM
schreiber   Made some good progress this weekend! I replac...   Sep 2 2008, 09:34 AM
plymouth37   Looks like you are well on your way to a great cle...   Sep 2 2008, 11:09 AM
ChrisNPDrider   Cool :beer2: Those side mirrors look like the pl...   Sep 3 2008, 01:35 AM
SGB   Hey Jake! Saw you go down the street this wee...   Sep 3 2008, 08:05 AM
nsr-jamie   Cool, always love seeing other peoples projects. A...   Sep 3 2008, 08:41 AM
schreiber   Ok 914 world, I need some help. I'm under the ...   Oct 11 2008, 12:00 PM
jmill   Those are cheesey spacers to make up for sagging s...   Oct 11 2008, 12:04 PM
Wilhelm   Those would be the JC Whitney style spring spacers...   Oct 11 2008, 12:08 PM
schreiber   Aright. Thanks for the help!   Oct 11 2008, 12:10 PM
schreiber   OK gentlemen, I need some assistance. I was wantin...   Oct 22 2008, 03:45 PM
SGB   Hey Jake! Probably need new spark plugs. They...   Oct 23 2008, 09:03 AM
schreiber   Scott, I did changed the plugs a few months back. ...   Oct 24 2008, 05:44 PM
stock93   I just noticed you were in huntsville and wanted t...   Oct 24 2008, 06:53 PM
schreiber   Ok 914 world, I need some help. I'm under the...   Feb 24 2009, 09:33 AM
ConeDodger   Ok 914 world, I need some help. I'm under th...   Feb 24 2009, 09:39 AM
schreiber   I think I found some springs that are going to wor...   Feb 26 2009, 02:50 PM
schreiber   Last post was in February. Is it evident that this...   Aug 14 2009, 09:58 PM
jmill   Lose that plastic tee. Plastic bakes and cracks th...   Aug 14 2009, 10:11 PM
schreiber   Lose that plastic tee. Plastic bakes and cracks t...   Aug 14 2009, 10:44 PM
kwales   Yup. Metal is good.   Aug 15 2009, 12:00 PM
schreiber   Plastic tee replaced with better metal tee. Also h...   Aug 23 2009, 09:01 PM
CliffBraun   Not the linkage I have in my car, so I can't t...   Aug 23 2009, 09:21 PM
schreiber   think everything is in place. only problem now is ...   Aug 28 2009, 08:52 AM
Mark Henry   think everything is in place. only problem now is...   Sep 1 2009, 05:23 PM
rick 918-S   think everything is in place. only problem now i...   Sep 2 2009, 07:30 AM
rjames   keep the progress up! :) Did you ever fig...   Aug 28 2009, 03:05 PM
schreiber   Feeling discouraged. :( After working on the car...   Sep 1 2009, 09:52 AM
SGB   Jake! I saw that your car was out of it's...   Sep 2 2009, 08:55 AM
schreiber   Jake! I saw that your car was out of it...   Sep 2 2009, 09:07 AM
schreiber   Many thanks to pilothyer, he came over this weeken...   Sep 6 2009, 09:48 PM
schreiber   successfully yanked out my old accelerator cable a...   Oct 3 2009, 08:50 PM
schreiber   Closing this thread since this car was sold severa...   Sep 14 2015, 10:19 AM
JRust   That's a relief. Seeing as nobody had posted b...   Sep 14 2015, 10:36 AM
schreiber   That's a relief. Seeing as nobody had posted ...   Sep 14 2015, 10:41 AM
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 06:24 PM
