8" wheels with Cantilevered Slicks, What is the conventional wisdom? |
Randal |
Sep 2 2009, 01:57 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Found a place that will widen cookie cutters somewhat reasonably. Either on the inside of the wheel or the outside. I know where I want it widened, but my question is what does the extra inch do? Does it make the cantilevered slick stay flatter or ? Do you want the wider wheel in the front (?) or just the back? JP.... time for you to jump in here! |
john rogers |
Sep 2 2009, 11:29 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
Goodyear told me they were designed for 7 inch wide rims and the movement is to provide some flexibility to the car. At the time the SCCA mandated 7 inch max width along with a max width between the inside rims in a lot of classes and magically Goodyear figured out a way to make a 9 1/2 wide tire fit onto a rim that was so narrow and the SCCA hated they for it.
Personally, I would be leary of using alloy rims that were originally cast/forged as one piece and were cut and widened. If they were Centerlines or any other brand of 3 piece rim that can be widened then I would say it would be safe. |
Lo-Fi Version | Time is now: 31st October 2024 - 07:22 PM |
