914 Transmission dimensions |
mkincaid |
Sep 3 2009, 04:05 PM
Newbie Group: Members Posts: 7 Joined: 3-September 09 From: Seattle Member No.: 10,757 Region Association: Pacific Northwest |
I was hoping someone could point me at a 914 5 speed transmission drawing. I'd like at least the vertical dimension from the input shaft to the output shafts, and also the longitudinal distance from the bell housing surface to the output shafts.
I'd also be very greatful if you could include approximate overal dimensions. Thank you much, MK |
GS Guy |
Sep 4 2009, 06:10 AM
Member Group: Members Posts: 243 Joined: 8-July 04 From: Columbia, MD Member No.: 2,325 Region Association: North East States |
I was hoping someone could point me at a 914 5 speed transmission drawing. I'd like at least the vertical dimension from the input shaft to the output shafts, and also the longitudinal distance from the bell housing surface to the output shafts. I'd also be very greatful if you could include approximate overal dimensions. Thank you much, MK From my notes: Overall length: 23-3/8" (case end to end, not inc. input shaft) Overall width: 17-3/4" (@ mounting ears - think this is the widest part) Bellhousing width: ~14" Bellhousing face to output flange CL: 7-7/8" (horizontal dimension) Input shaft CL to output flange CL: 2-9/16" (vertical dimension) Jeff |
Lo-Fi Version | Time is now: 1st February 2025 - 06:56 AM |
